When I'm riding and coming to a stop I push in the clutch my rpm stays up until I let out on the clutch a little then my rpm goes down and everything is ok is my throttle cable sticking ?
It seem to be the cable my trooper does the same thing i unplugged iac it still do that sometimes. When it sticks i would reach behind me and shut the throttle body by hand.. i have intake that is built by goindeep
Guest Lenny
Just any way that works. Mine is different so what I'm doing doesn't matter. Make sure that the spring doesn't pull over center so as to want to hold the throttle open when wide open.
Kinarfi that's an interesting idea i never seen that way before. Lenny that's good idea and i forgot yours was supercharged so different locations. You are right i would want to try have it pull from closed side to keep it from going over center
  • Popular Now
    • By esmarkey
      Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in.  It still acts like the belt is slipping but now I am thinking it is the clutch?
      Can the clutch be rebuilt?
    • By Stan M
      I have a 2026 Massimo 760L and also the Massimo snowblower attachment and would like to do a permanent install on the control cable and switch. Does anyone have a recommendation regarding the routing of the cable and mounting of the control switch?
    • By J Cardwell
      2024 villian overheating shuts down to crawl mode. If I turn it off for 30 minutes power returns to normal.
    • By oakhill
      When I am moving forward on my Hisun 500, the motor accellerates up and down while I have my foot on the gas pedal.  It also is not idling very well.  Both symptons appeared at about the same time.  What should I look for?  Thanks.
    • By jdeaton01
      Hi, I have a 2015 i believe,  landmaster lm400.
      I am installing a duromax 420 to replace another oddball honda knockoff ( the black and yellow one).
      I am having difficulties removing the primary clutch.  I dont know which tool to order. It's like the best kept hidden secret. Idk if i need m12, m14, or whatever size tool i need. Any help would be appreciated
