explain please
what happened to the temp sensor that was there, is it gone, it sends a signal to the computer so that the computer can adjust the fuel to the temperature.
https://www.dropbox.com/s/561djpqwan1re88/1100%20Trooper%20T2%20ECU%20Wiring%20Diagram.pdf
find A08 in the above file, if you want to take a chance on burning a hole in the piston by running too lean, you could substitute a resistor, but I would suggest putting the original back and find a different place for your manual gauge.
the old one quite working i took it out it broke doing so. i retaped the head to standard thread for maunal gauge. will a small rezester work? an do i power that pin?
It has been a long time since I messed with my temperature sensor, but I think it may have been 2 sensors in one, one for the computer and one for the gauge, if I remember correctly, you can measure the resistance from terminal to terminal and from terminal to ground.
I don't know how or if the computer uses these readings, except to guess that if the computer thinks the engine is hot, maybe it dumps lots of fuel into it trying to keep it cooler, or if it thinks the engine is cold, it richens the mixture for easier ignition. I do not know. and I don't know what value of resistor to suggest.
I guess my suggestion would be to buy a new standard sensor and figure out how to put it back in.
When you get the new one, can you take some measurements?
First, do you have a good Ohm meter? If so, can you measure the resistances of terminal to terminal and each terminal to case while in a bath of ice water, then while in boiling water or hot oil if you have a way to measure the temperature,
The computer does need the temp sensor to work correctly.
Dave, Did you get it fix what did you do?
NO NOT YET i put new temp sencor in did not help . but i didn't wire the gauge back up. so i'm going to put gauge back in an see what happens,
Which sensor Lenny - the one at the head or the one on the radiator at the bottom?
I took the Rad one out and put my temp sensor there, and have had no running issues at all. Hopefully I pulled the right one...
The one in the heads is the one that the computer is interested in.
    • By Sammy
    • By jertex
      I have two questions:
    • By OBL
    • By AaronD1982
    • By Fmaxiron
