Looks like same pattern as what came on my t2 stock (far east) it was good for all around and being light. I think I'll look for lighter tires next since mine is really heavy at about 40 or so lb each. Outlaw 2 29.5x9.5x14 front 29.5x11x14 in rear
Sent from my SM-N900V using Tapatalk
Plumber, where you looking at price? or the best tire? also what size did you need? The tire for the money the Outback is a 6ply tire and has a larger lug depth and a thicker side wall, where the CST Ancla has a thinner side wall and smaller lugs.
The two best tires I have used is the GBC Mongrel and the STI Roctane
Mongrel :
http://www.gbcmotorsports.com/kanati-mongrel-p-216.html
Roctane:
http://www.stitireandwheel.com/2012/12/roctane-xd/
nocturnalsixer,
You have never heard of the Mongrels or the Roctane? They are definitely the ticket - I prefer the Mongrels, but from what I have heard from people they like them both. I havent really got a chance to try the Roctanes in all the terrian that I have with the mongrels.
    • By HighSon
      Locking gas door.
      Rear view mirror.
      Folding armrests.
      Folding rear seats.
    • By Rmillerdesigns
    • Guest
      By Guest
      Good afternoon,
      I have a 2022 Bobcat 34XL.  Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start.  Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
      TIA
    • By JBF
      I bought a pair of Rough Country pod lights and it comes with a 3 pin plug(black, white and blue) I want to hook it up to a lit 5 pin rocker switch but I don’t have a clue what pins do I need to connect it to. I wired it to the keyed switch. Chat GPT as good as it might be does not know what I am asking. Any help would be greatly appreciated!
