Looks good. Now you will have a little extra piece of mind. The v bracing is a must if you are using the stock cage. Be sure to send us a pic when you are all done.
2scoops, Thanks yes I will be doing the v up front and a few more things. Yes that's why I done it there are some hills I don't even try because I didn't think the cage would hold up. I'll should have it done by this weekend I'll post more pictures.
off subject but did you flip your intake and how did you do it
toddlong. No I didn't flip my intake I bought the bottom part of the intake. All SQR 472 engines comes with this intake on them except the trooper. How I like it I think it's better than the fuel controller. Just bolt it on my motor and it made my A/F gauge go up by .6. If you look at the picture it's fatter than the ones joyner has on it. Here's the part number or my be you can fine a used engine to get the part off of it. It just bolts right on. .DLJ.472-1008013
    • By SkyPilot56
    • By Karlibob
    • By A P
    • By clint501
    • By Robbie Wyre
