New (used and abused) 2008 Joyner Trooper T4
By Tim n Deb
By Jon V
By Havoc321
I’m looking to have my 2022 800sx fit in the 10’ garage of my toy hauler. I thought about removing the dump bed, so I wondered how far the dump extends beyond the tires. Thanks!
By great8redsfan
