New (used and abused) 2008 Joyner Trooper T4
By great8redsfan
By johnpeter
RZR 1000 XP EPS - Rocks & Trails Edition 2020 On Ebay
https://www.ebay.com/itm/355474995514?
By Rizzguy
Don’t waste your time everybody with rpm motorsports, Omaha. They are people that don’t even work on sxs’s. Trying to tell you how to install things.
Completely uneducated guy tried to tell me I did not install a mid pipe correctly when it won’t install correctly; that was the reason for the video and the complaint that I called him about.
This mid pipe has a 1 inch gap at the rear, and the only way to close it up is with a longer bolt, and to stretch the flex at the Exhaust
After one ride, the rear bolts have disappeared, because how much tension there is on the flex
And the bolts does not line up at the flange
Have a video before and after. And they are telling me that it’s my fault because it does not fit
wtf.!
What kind of idiotic people are even answering the phones these days.?
This guy has probably only read a book and never even driven a motorcycle in his life
Don’t waste your time with this bullshit products
By Michael Flippin
I have a 2023 T-Boss 410. The starter is just spinning but nothing is turning over. It was working fine and just stalled. Tried to restart and starter just spins. Thought maybe the interior of the starter broke. Ordered and installed a new starter and it does the same thing. You just hear the starter spinning but does not seem like anything is catching. I checked the gear the starter engages and that is clean and turning freely. Any idea what the issue could be?
