Thanks for the information. If I can't find anything closer to home I may be loading up and making a trip to Yuma. I hear its lovely this time of the year.
Thanks Rich,
I would appreciate any help I can get. The buggy was running just fine when I shut it down for the summer months. It was stored in an enclosed trailer but left out in the desert over the summer. I guess the heat was too much for it. I suspected bad fuel so I drained the tank and replaced the fuel but all it does is turn over. I'm not sure if it's a fuel or electrical issue. That's all the troubleshooting I have done so far. I haven't really worked on engines since they've had carburetors so I don't have any experience with fuel injection. I can read a manual but don't really have the time or place to work on it. If you can give me any tips or get me going in the right direction I will definitely give it a shot and see if I can figure it out.
  • Popular Now
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
    • By Jody Deville
    • By Timbo
    • By Sharon
