Opinions of various UTV models/brands?
Popular Now
By HISUN Sector 750 EPS Failu
By Chukarman
When riding for an extended period in 4wd the check engine light comes on and transmission locks. If I turn off vehicle and wait about an hour it seems to reset. The check engine light is no longer on and it runs fine. Any idea what causes this and how can dealer diagnose the problem if check engine light no longer on.
By UTVLover253
What you love about it
What frustrates you
If you're open to hopping on a casual 30-minute Zoom or phone call sometime this week or next, I’ll send you a $100 gift card as a thank-you.
No sales, no pitches—just listening and learning. I'd also just ask that you send over a photo of you and your side-by-side in action (nothing formal—trail pics or selfies are totally fine!).
– Adam
By sxr951
