Joyner trooper electric power steering for $200..
By rdc
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
By 180gtr
Wheels
Tires
Engine
Transmission
Axles
Shocks
Control Arms
Throttle Body $90
Starter $150
Alternator $150
fuel pump $70
Map Sensor $50
Full set of Guages $150
Exhaust w cat, O2 SOLD
Ignition Coil - SOLD
Wiring harness and ecu SOLD
That would include....
Steering shaft, wheel
Ignition switch, key
Light bar frame, 2 lights
misc hardware, spindles
2 hubs, rotors
Engine mounts
Throttle pedal, cables
Shifter, cables
Clutch master, pedal
By Jody Deville
By Rmillerdesigns
