    • By AlphaSerenity
      Hello,
    • By chuck92308
      I am throughly discussed with the 800sx.  It has a lot of suspension cracking and squeaking from the suspension/shocks.  Also been to the dealer 4 times for excessive drive clutch/belt squealing.  They have no clue and they have (supposedly) changed both clutches and drive belt. Anyone having any of these issues.
    • By Sharon
    • By Stan M
      I just received my 760L a couple of days ago and it's been difficult to shift between gears from the get go. At first I could rock the unit and it would free up for a while but now it's just stuck in reverse and rocking doesn't work. I had the UTV delivered directly from Massimo and there aren't any service centers in my area. Any ideas? Thanks
    • By Pilot1996
      So my 2022 Tracker 800SX developed a coolant leak. Under pressure there was a pin hole size leak which was spewing coolant towards the firewall. Upon removing the tank I discovered it was bulging pretty severely such that it caused a small crack. Has anyone else experienced this? I suspect either a faulty tank or perhaps a faulty tank cap (rated at 15PSI).
