Trooper has intermittent starting..
Tobie1987
My trooper intermitts when it wants to start.. it will always start cold..but if you shut it off it might start again and it may not.. it won't fire..but it you wait 5-10 mins it will start up just fine again until you shut it off.. I can't figure it out soo it's been idel if a lot lately..
Sent from my iPhone using Tapatalk
If that is the stock gauge, it probably isn't correct mine was showing 45 psi and when I put another one I had in the shop, it was more like 25 psi.
Go ahead and change your plugs (cheapest 1st) but I've never heard of plugs getting hot and not working.
Fuel pumps and ignition coils usually. Keep us informed on how the plug change goes.
Yes.. i also turned the fuel pressure down to about 50-52 psi.. it wasn't running rich.. air/fuel gauge is running at about 14-14.5 warm..I took it riding the other day for about 6-8 hours and i had to wait for it to start a few times that morning but after that it hasn't don't it anymore.. I don't know for sure but I think it's was because i had it very very rich before and now I got it running pretty go now..
  • 2 months later...
Glad you figured it out. At the end of the season last year Mine was dieing on me when coming off throttle from time to time. Then it didn't want to start afterward. I found oil in the intake and on the intake sensors. Also found a suspect air leak in a cracked intake rubber plug.  Cleaned the sensors and filled the plug with rtv and is running great. Keep an eye on rubber parts. They are always cracking.
    • By great8redsfan
    • By malenurse13
      We just bought a used 2017 American Landmaster TW450. No hour meter that I can find, so not sure exactly how much it has been used.
      The first 2 days we had it, the starter was a little sketchy, but it started after 2-3 tries. Sometimes when turning the key, we would hear a loud metal "clink" sound. Like the starter made contact, but didn't have enough power to turn.
      THIS MORNING... Turning the key, we hear a single click sound. That's it. Even with a new battery, the starter is still doing the same thing. Both batteries (old and new) were reading 12.8 volts on volt meter. So I'm wondering what else could be going on? Any ideas on what to look for would be greatly appreciated...
      Thank you!
    • By donwan
      I have a part that fell over to the exhaust and burned the harness up. I can't figure out what it is. Does anyone know what the start relay looks like? The part I can't figure out has 4 wires, a red power, a green and brown wire, a black and unsure what the 4th color was. Anyone have a clue?
    • By MOTORHEAD1959
      ATV just clicks when trying to start. Battery is good, has a new starter, and all the wiring looks good. any suggestions on where to go from here? thanks
    • By DJ Brusenski
      checked all the fuses and relays, I can jump start it with the key in the on position. it will not key start need some help, thanks
