Also i had another question about the charging system if anyone could help me out... i was testing the wires at the plug on the alternator.. both wires going in have 12v.. before it is started.. does this sound right? Or might i just have a wiring issue?
On 12/10/2017 at 11:32 AM, silverbullet said:
silverbullet
The price is 169.00
Thanks Rich
Id like to buy the alternator.. how do i go about doing so? Do you have a website? And is this price shipped?
    • By Xov
    • By Tim n Deb
      Has anyone installed the power dump on a Kioti K9? If so, does it eliminate the safety lock? Does it work well?
      Thanks for your input
    • By monkthumper
    • By Gerald Dillman
