Hisun Sector/Vector 250 Service Manual?
Popular Now
By Burk
By HISUN Sector 750 EPS Failu
By Hunterman22
Can anyone please tell me or send a link as to how & where to hook up a code reader to my 2021 Hisun 500 Axis. I have a 6 pin to a 18 pin adaptor and the blue cord VAG KKL adaptor .Just not sure where or what to hook up to. Can I use your typical vehicle code reader or do I need to download something on a laptop or PC???
By Butch
By Eman85
