LED light bar 🔥Promotion Best Price 🆕🆕
By brewski
By strike250
Matt
By Razorair
New to this site I just got this 2014 Coleman UTV 700 High Temp Light on from the start cold I haven't really ohm checked the sensors although they are all new but I have done lots of work on the engine I've replace the head gasket, wet clutch rebuilt the primary clutch and cleaned the secondary clutch with a new belt plus a bunch of other stuff I just can't figure out this high temp light that is on at start and has never been off. I have bled the air multiple times. I also wired a switch for the fan to run it most of the time due to others that have suggested this. It is running good the radiator is getting warm but really haven't ran it enough to make sure it's not getting too hot but I just want the light to work as it's suppose to. I would really like to install a true temp gauge if anybody could help with doing that.
By ejt
I upgraded the lighting on my 1988 Mule 1000 KAF450. Changed the ancient dim headlights to LED bars and the 1157 taillight bulbs to LED as well. They are flickering / pulsing at a pretty fast rate. Anyone else experienced something like this? I've heard that this kind of problem can sometimes be fixed with a capacitor. The resistor fix for hyper flashing on cars doesn't seem right for this issue.
The fuel pump makes a fast ticking noise and the flickering of the lights seems to be in sync with that. Don't know if the fuel pump is creating some sort of interference in the electrical system. The flickering happens whether or not the engine is running. I connected one of the lights across the battery terminals to test it and it lights up beautifully with no flickering.
I would like to see if anyone with some more electronic chops than me has dealt with this problem before. Thank you.
By relsiswb
I have a 2023 Massimo Buck 450. The MIL light was on one day. I noticed that the oil level did not even touch the dipstick. It has always been fine before. I topped off the oil level and it has stayed up since then, although I haven’t been running it much. First off, will the oil level turn on the light? Second, is there a way to reset the light? I have an OBD 2 reader but I don’t see a port.
