I have a HiSun HS700 (686cc one cyl.) and needed to do it's first oil change. I found that the Chinese oil filter CF188-011300 had a Fram cross-reference to a PH4967 so I picked the Fram filter up at Walmart along with the recommended 10W40 motor oil.
I removed the oil fill plug and then the drain plug, followed by removal of the original factory oil filter. The oil drain plug and original filter were extremely tight. I did not have the 67mm oil filter wrench and bent the filter up pretty badly using channel lock pliers.
Replaced the drain plug, and the filter and the fill plug after putting in the required 70 ounces of oil and started it up.
I shut it down almost immediately but not until a little over a quart of oil squirted out from the oil filter's rubber seal.
Yes, I had lubed the new filter gasket and made sure the old filter gasket was not left behind when I removed the old filter.
I went to the store and bought the oil filter wrench and removed the Fram filter. I saw nothing wrong with the seating area or the gasket so I put it back on (making sure it was as tight as I dare without stripping it) and added the missing oil. I stood on the side of the motor where I could see the filter while I started the engine again. Again the oil started to squirt out.
I removed the Fram filter and reinstalled the bent original and topped off the oil again. I started the engine and it is not leaking now.
Anyone have this issue? Is the Fram filter a true replacement? Did I just get a new filter with a bad gasket which is not visibly bad?
Hi there,  I have had this happen to me once on my Mule several years back with a Fram filter. I then put a  Wix filter on it, and it did not leak.   Not saying this is your case, just a possibility.
Wix 51065
Wix 51360
Wix 51394
Wix 51395
Wix 51396
 Found these on a oil filter cross ref. that should fit your hisun. double check though,
Thank you Travis, I will order one of the WIX filters when I find the right one for my UTV.
Would you please post a pointer to the cross-reference chart you are using?
In the mean time I have ordered a "CFMOTO" CF188-011300 on line to see if that works.
Thank you also Vaughn.
Late yesterday afternoon I received the CFMOTO CF188-011300 that I had ordered and I put a paper towel under the old filter, removed it, cleaned the seating area and put a light coat of oil on the new CFMOTO filter gasket and installed it.
NO LEAKS !
The gasket is very different from the FRAM. A side view of the FRAM gasket would look like a small hard (firm) square. A side view of the Chinese filter would look like a wider soft oval.
Since the CFMOTO is not easily available locally for me, I downloaded the cross-reference list than Vaughn provided for future reference.
It would be interesting to have a list of filters that are common to fail for this application. I would add the FRAM PH4967 to that list.
Sadly, the FRAM PH4967 is listed on the cross-reference that Vaughn provided (no negativity to Vaughn intended). I'm sure the PH4967 is also on some other cross-reference list because I got that number from somewhere.
Just a follow-up note. I looked through the cross-reference oil filter list provided by Vaughn and the other provided by Travis and noticed that they both list the Kawasaki 49065-7010.
I park my UTV in my garage and I park my Zero turn mower in the shed.
I have not tried the filter on the UTV yet but the Kawasaki engine on my lawn mower uses the Kawasaki 49065-7010 and I have a new spare for the mower in the shed.
If I had noticed this in the beginning (if I had these cross-reference listings), I more than likely would not have run into my problem. I will try the Kawasaki filter the next time I change the filter on the UTV and it will be my "go to" filter for both machines.
  • 4 weeks later...
Not only let us know if it works but how much it cost too if you don't mind.
Please post a picture of the gasket side of the filter you are getting. I noticed a significant difference between my original and the one that failed. The one that worked was very much like the original.
Others have posted that they used the brand/type that I had fail so I may have had o defective one. I could not see what made it (the FRAM) leak severely, but it did.
So the Hisun Oil filter was the only one that worked. It had a much rounder gasket than any of the others.
The supertech leaked the least but still leaked under pressure.
The Hisun pictured above was $8.00 plus $7.75 shipping off of Amazon
Hope this is helpful to someone. The UTV is a 2015 Massimo 400.
I do believe the "CFMOTO" CF188-011300 I used successfuly looks identical to the "HiSun" in your pictures Kannon09. It was only $7.99 and shipping was free if you want to give that one a try.
By the way, I believe the engine block is the same for the 400, 500, & 700 UTV's.
  • 3 years later...
I have been pulling my hair out trying to find the right wrench, pliers type or cap wrench to remove the oil filter from my Hisun 500.  Lowe's is absolutely no help (yeah, it's an Axis 500 sold by Lowe's).  Any help would be most appreciated since the hair is almost gone at this point.
  • Alex changed the title to HiSun HS700 Simple oil change... NOT !!!
I have the same machine from Lowes and found that a grip wrench with the rubber strap works perfectly.  Also found a replacement oil filter at Tractor Supply.  I can get the number if you need it.
The filter is a purolator L14612
Thanks for the info, Robert.   Found a great video on YouTube from Mountain Buck where he showed a wrench that he used to get that stubborn filter off.   I just bought one from Amazon but haven't used it yet.  It's a Lisle 6300 Filter Wrench.  Also, bought this filter on Amazon:  Chikia Massimo Oil Filter for Hisun ATV UTV 250,400,450,500,550,700,750,ODES 500,650,MSU,Bennche,Cub Cadet,Yardsport,AXIS $9.99.  This filter got 87% five star reviews.
  • 5 months later...
    • By Geneg
      I am actively looking for an oil filter for my Lowe’s branded Axis x550. Lowe’s sold me a spin on filter but every video I’ve seen shows a cylinder filter. Of course Hisun’s website is a year behind not listing anything 2025 and my searches have turned up nothing. Does anyone know what filter I need ( cylinder or spin on) and where I can find one?
      thanks
    • By Aaron Colona
    • By Karlibob
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
