  • 2 months later...
no one has gotten back to me
On ‎1‎/‎16‎/‎2019 at 2:55 PM, strike250 said:
Has anyone gotten back to you regarding this issue. I can help you if you are still having issues. matt
Well, I know a little about these clutches. are you still having issues with them? And if so, what is happening to the wet clutch. and second, are you having any issues with the outer clutches at all? When you replaced the clutch, did you use an OEM clutch or an aftermarket one? Did you replace the one way bearing as well. and when you replaced the clutch, did you replace the outer clutch drum?
Matt
When you say you went through both clutches in just about 250 miles, I'm guess the replacement clutch was worn and possibly had wear marks on the clutch hub as well? did you do any work to the primary and secondary clutches at all?
The Yardsport YS400 is a mix of parts from the Yamaha parts bin. The manufacture is HiSUN, who also happens to manufacture parts for Yamaha and more OEM's. The bottom end is basicaly the same as the Yamaha 350 Grizzly/Bruin. The top end is more of less off of a Yamaha Kodiak 400, early 2002 style. I would start by using OEM Yamaha parts for the clutch. 2007-2011 Yamaha Grizzly 350 wet clutch. the parts are of higher quality than the Chinese counterparts. This might be part of your problem. They bolt right on and will work and last much better.
thank  you , those part no. s   are the wet clutch , do you  have the no.s  for the secondary clutch all I really need is for the secondary sliding sleeve
thanks for all your help
  • 2 years later...
  • Popular Now
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By Timbo
    • By Sharon
    • By Rocahaja
      Dumb question probably but what size drive chain is used on  Massimo gunner 250? I believe it to be 520 but not sure.  Thanks for helping
    • By Bigmountainrider
      Hi Team,
       I'm new to the Forum, and I'm looking for your help. I have a 2009 Yamaha Rhino 700 that has stopped consistently charging. Here are the specs and Info I can provide, the Stator and Regulator are new. The Stator does not have continuity to ground on all 3 wires at the engine bay plug. The stator puts out 15-17AC/V at Idle and 38-39AC/V at 2000rpm at both the engine bay plug and the regulator plug. The Battery regulator plug has Battery DC Voltage, when Running the regulator puts out Charging voltage 13.4-15V. I have upgraded/added ground wires from the primary battery to the engine block, from the stock ground wire bolt on the engine to the Chassis and from the secondary battery to the regulator grounding bolt/ground wire. Now the symptoms are it Charges when first started and will continue to charge while driving or at high idle until the machine returns to idle- it will not charge after that, this includes any RPM. If your shut the machine off and restart the process restarts -it will charge until returned to idle. The Machine has and RM Stator and Regulator and a Kimpex Flywheel. The last time it was driven it had an overheating event- unrelated to charging I think, but worth the mention.
      Any thoughts would be helpful, I have the factory Regulator- it was working at the time of replacement- when swapped the same issues occur.
