Hi Everyone, This is my first post.  I believe I have my starting issues narrowed down to decompression springs (good grounds, one way bearing, etc.) so I order them and now I have no idea how to install.  I am handy enough, but looking for a video or other instructions on how to replace them.  If this has been covered and I just can't find it, appreciate some input on where to go.  If not, would appreciate some instruction!  Haven't done this one before.  Thanks.
I am not too familiar with your type machine, but if im thinking right they would go on the camshaft.
Here's another thread about this issue, Thread   <--- Click.
 But i do have to ask, have you checked your valve lash/clearance?
I assume the engine is slow to initially turn over. We found the cause to be incorrect cam setting not opening valve when it should. Take the rocker and side cover off and you can see how and when it should work. Fixed it by adjusting. You won't find anything relevant  in the service manual.
    • By Skeeter22
    • By Cliffampranch
    • By Firewalker918
    • By mehe
