Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in. It still acts like the belt is slipping but now I am thinking it is the clutch?
Can the clutch be rebuilt?
I'm having another issue with my 2019 Buck 400. When I push in on the brake and turn the ignition to start nothing happens. If I pump the brake several times it will start right up. Does anybody know where the relat is that prevents it from starting until you apply the brake? I think it must be loose or something like that.
Thanks for your help.
Hi, I have a 2015 i believe, landmaster lm400.
I am installing a duromax 420 to replace another oddball honda knockoff ( the black and yellow one).
I am having difficulties removing the primary clutch. I dont know which tool to order. It's like the best kept hidden secret. Idk if i need m12, m14, or whatever size tool i need. Any help would be appreciated
