Hi, I have a 2015 i believe,  landmaster lm400.
I am installing a duromax 420 to replace another oddball honda knockoff ( the black and yellow one).
I am having difficulties removing the primary clutch.  I dont know which tool to order. It's like the best kept hidden secret. Idk if i need m12, m14, or whatever size tool i need. Any help would be appreciated
If you haven't got it yet, If you're talking about the clutch to the motor, I would just put whatever socket fits the tightest and go from there. Could be sae or metric.
I know Landmaster does have a decent online support as far as engine, tranny, motor, etc, manuals. You might be able to find a diagram breakdown?
 I know there have been a couple of HF retrofits on these forums and Youtube if you haven't looked at them yet, they may have some ideas on other things you might run into also.
    • By BWF
      I have a 2011 or so Landmaster LM200.  I cannot get it to start.  I turn the key and nothing happens.  The brake switch seems to be working, the ignition switch works.  The Coil is new the Voltage Regulator is new and the starter relay is new.
      I can connect the terminals on the starter relay and it starts right up and runs fine.  I just can't get it to start by turning the key.
      I am having a bit of trouble bleeding the brakes, not much fluid comes out at the calipers when I am pumping the brakes, though that an air bubble near the brake switch might make it not sense that the brake pedal is depressed.
      I am at a loss, please help!
      Brad
    • By Fmaxiron
      Thanks a lot!
    • By esmarkey
      Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in.  It still acts like the belt is slipping but now I am thinking it is the clutch?
      Can the clutch be rebuilt?
    • By brewski
      I just purchased a 2025 kubota rtv 1100 x cab esd esnting to install light bars on the roof it appears to be prewired for lights how do lights mount and what kind of switches do i need
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
