2014 Mule 4010 Trans. Need windshield advice
By jertex
I have two questions:
By OBL
By Bucky4444
Has anyone found a decent replacement for the factory mirrors on a 2020 1100C? My 2011 1100 and 2020 1100C both have the same mirrors and Kubota hasn't made one improvement to the design during those years. Haven't checked the newer models so maybe Kubota finally woke up. Mine are definitely in need of improvement. .
By Blekntowkz
Any advice would be huge.
