Ok trying again... I have 2018 cub cadet 750. Having clutch issues. Has anyone bought a upgrade for them and where did you get them and about how much. Thanks for any help given. From what i have looked over on here. Lots of nice helpful people
The clutches themselves. There is like 3 of them I guess. Wet clutch primary secondary from what I hear. My problem is taking off and can't get my speed anymore once it does grab good.
  • 2 months later...
I just put in a EPI clutch upgrade. My starting system is messed up so I can’t review it for you yet.
Putting it in was not too bad. Buy the tool for the secondary clutch though. No way to do it safe otherwise.
  • 5 months later...
How did u make out with your clutch
  • 11 months later...
Misfiring after shifting from low to high.
After shifting gears the cub 750 challenger starts to misfire and barely will run. Any suggestions. It idles great and runs good until it shifts. 2018 year.
  • Popular Now
    • By esmarkey
      Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in.  It still acts like the belt is slipping but now I am thinking it is the clutch?
      Can the clutch be rebuilt?
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By RBonds007
    • By RBonds007
      Looking for an online parts store.  Just need basic maintenance parts tune ups and such.  Any suggestions?
    • By CarlB
      I have a 2022 Hisun 750 Sector which comes with a locked rear differential. Was wondering if it would be possible to install an unlocking differential.  I see that there are some Hisun made machines that come with the unlocking rear diff, such as Cub Cadet Challenger, some of the Massimos, and probably others. My concern is whether these would be a direct bolt on, using the original axles, drive shaft, and of course matching gear ratio. I've tried to match up part numbers but it seems every brand has their own number system even for parts that I know are identical. If anyone has ever done this swap or has any information about the whether these unlocking rear diffs are comparable to the Sector, I'd appreciate your input.
