I traded my Harley Davidson Softail for a 2015 450i and some cash. The whole time I have had this unit,it has had a very hard brake pedal. I think the hard pedal condition was there long before me,because the pedal arm has been bent ,I think a long time. Any Ideas where and how I should approach the problem??
If no single tire locks up I would try taking the master cylinder off and flushing it out with new brake fluid. Just let it squirt out and see if it got clogged. If you’re handy then I would take it apart also and check if the seals are still good. It would be odd if all 4 caliper/slave cylinders would all be bad at the same time.
Just for the halibut I would also make sure the main brake lines haven’t been crunched by seeing how much brake fluid comes out of each wheel? Do they bleed the about the same amount of fluid?
 That’s my guess, good luck…..
  • Thanks 1
    • By AaronD1982
    • By HighSon
      Locking gas door.
      Rear view mirror.
      Folding armrests.
      Folding rear seats.
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Jamie 67
      Why is there 2 different length keys for my tboss 1000?
    • By Rmillerdesigns
      Hello. I have a 2016 Massimo MSU 500. I was putting on a lightbar and i screwed up and didn't disconnect the battery so when i was taking of the positive cable to put on the power from the lightbar it sparked and now the utv has no power. I turn the key over and all i hear is a chirp. No lights or anything. Everything that comes from the battery to the jumper box up by the battery shows voltage but anything coming out does not such as to the winch or anything like that
