5110 error on hisun sector e1
Popular Now
By Burk
By HISUN Sector 750 EPS Failu
"Mrs. Smith" doesn't like how loud our Sector 750 is. On a HISUN forum someone said the same thing about his 750. I haven't given it much thought because I've been more focused on stuff that has broken.
So, I used my decibel meter to check ours out. 4000 RPM, Low gear, under 20 MPH . . . . 97 decibels. That's above most ordinances, even state boat noise limits.
AI Overview Ninety-seven (97) decibels is considered very loud and dangerous to hearing with prolonged exposure, roughly equivalent to a newspaper press, a loud nightclub, or a snowmobile. At this level, damage can occur after just 30 minutes, necessitating hearing protection -
By Mitch13
2022 Coleman 400 with 13 hours on the engine and the mice got to it. Every wire coming out of the steering column in one cluster has been eaten through. I tried reconnecting matching wire colors to each other and I get the left turn signal and hazards to work, nothing else. If I play around a bit I can get the horn to honk or headlights to come on but only when I connect them to the brown wire. Obviously I don't know what I am doing here. Does anyone have a picture of how these wires are connected when they are under the hood on the drivers side coming from the steering column?
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
By Hunterman22
Can anyone please tell me or send a link as to how & where to hook up a code reader to my 2021 Hisun 500 Axis. I have a 6 pin to a 18 pin adaptor and the blue cord VAG KKL adaptor .Just not sure where or what to hook up to. Can I use your typical vehicle code reader or do I need to download something on a laptop or PC???
By Butch
I have a AXIS 700 EFI Fuel pump pressure stays at 40 psi and when return line is blocked the pressure goes to 60 psi. and wll only run with return line closed.
