TRACKER. OFF ROAD UTVs & ATVs “Discontinued” !!
By Cliffampranch
I have a 14 mile round trip on level roads to reach the property where I work with my 2025 Amp Crew Ranch (purchased, April 2026). That 14 mile round trip uses 60% of the battery as shown on the gage for a calculated range of 23.3 miles versus an advertised “up to 50 miles” range. A mile or two working on the property gets me a flashing gage and warning beeping by the time I get home. The dealer was good to work with and even with a new battery (yesterday) the results were about the same, although there seemed to be more power and a higher top speed. I own a Mach-e Mustang so I am familiar with how various conditions affect range, but less than 50% of advertised range just seems like there has to be something out of whack.
Now I’m wondering if there is a controller and/or software issue affecting the range and performance. At various points the Amp seems to lose power for no reason and then has trouble maintaining speed. Any ideas?
Also, twice now, the brakes seem to have not released fully. After noticing reduced speed, I stopped and check the rotors and wheel…..HOT! So, now every time I feel less power, I stopped to cycle the brakes and check the temperature. Very annoying. Are there any adjustments to be had?
Lastly, while an electric vehicle powertrain is quiet, my Amp was horrible from a road noise and vibration standpoint. This was easily fixed by locating panels vibrating on other panels or the frame (even the cup holders were vibrating) and installing felt adhesive pads at the contact points (seat to frame, windshield to frame, fenders to frame, etc.). This is a $10 and 1/2 hour fix that makes a significant improvement in the driver/passenger experience. Tire noise, yes, but that’s because of the knobby tread.
By chuck92308
I am throughly discussed with the 800sx. It has a lot of suspension cracking and squeaking from the suspension/shocks. Also been to the dealer 4 times for excessive drive clutch/belt squealing. They have no clue and they have (supposedly) changed both clutches and drive belt. Anyone having any of these issues.
By Burk
By Dave Jones
So with seat belt on I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
