I made my first oil change on a axis pro 750 I bought from lowes.  I found a substance that looked and felt like rubber bands in the oil filter and oil strainer at drain plug.  How in the world does this happen unless done on purpose at Hisun factory or assembly.  Has anyone else seen something similar?
Were the pieces hard like straw, or pliable like some sealant squeezed out into the interior and then broke off ?  Does it run ok? I would definitely follow up in 5 or 10 hours with another oil and filter change. Good luck
Pop Bob
Looks like crankcase sealant that squeezed out during assembly,good thing is it came out but like mentioned i would just change the oil and recheck,what if you refilled with a cheaper oil,run it for 30 min or so and then drain and recheck?
    • By AlphaSerenity
      Hello,
    • By dilger
      Transmission vent leaks oil out of it after using
    • By mike28honda
