2022 Coleman 550 Battery issues
By Rusmis91
I’ve never been around Coleman Utv machines. Do they have a good reputation, durable dependability. Could you compare them to yamaha rhinos or Polaris ranger
thanks in advance
By Adrian Domingues
Thanks for your help
By mrpro
I got the fronts adjusted. I'm trying to raise the ride height in the rear, but my spanner wrench keeps slipping. Is there an easier better way? It's like there's too much pressure working against me to be able to twist the height adjusters. How can I relieve that tension to make them easier to turn?
By Hoppy one
I replaced the stator on our Bennche 500 because it was not charging. It ran as long as you kept the battery charged. I replaced the stator now it’s not firing. The only problem I found was a wire in the new stator for the crank position sensor was in the wrong place in the plug. I switched it around but still no fire. Putting a meter on those wires and cranking the motor showed no voltage from the crank position sensor. Something I did or a bad “new “ part? Thanks for any ideas.
