What kind of light socket does your existing headlights have?
You might look around at LED lights as they make them for just about every socket you can imagine. As has been mentioned they also make 3" pod like light housings to 3'+ long bar lights.
Be aware tho, you have to read the description good as they sell "Spot" lights, (they have a slightly narrower beam) and "flood" lights (have a much wider beam). And each company has their own interpretation on narrow or wider beams. And they have a combo lights that have both, all in one. HF usually carries some LED pods like lights similar to what you can find on Amazon so you can see whet they look like. Mount them on your bumper and or roll bar.
 The good thing about LED lights is they also take less voltage to light so much easier on the charging system. They do get hot contrary to belief so most have a built in heat sink to take care of it.
I have a 12" NiLight bar out front, mounted on the hood just ahead of my access panel.  And 2 pod lights out back mounted on the edge of the roof.  Plenty of light in both directions.  Nilights seem to be pretty good quality as I also use them on my garden tractor for snow plowing at night.  Only thing is if you go trail riding, be aware that branches and brush can snag anything mounted on the exteriors.
    • By Rusmis91
      I’ve never been around Coleman Utv machines. Do they have a good reputation, durable dependability. Could you compare them to yamaha rhinos or Polaris ranger
      thanks in advance
    • By mrpro
      I got the fronts adjusted.  I'm trying to raise the ride height in the rear, but my spanner wrench keeps slipping.  Is there an easier better way?  It's like there's too much pressure working against me to be able to twist the height adjusters.  How can I relieve that tension to make them easier to turn?
    • By OBL
    • By AaronD1982
    • By Fmaxiron
