Landmaster 550 no front axle engagement
Popular Now
By AaronD1982
Next problem with charging system to tackle, any help would be appreciated.
New starter solenoid....check
New Voltage Regulator...check.
Dynamic test to Stator.....bang...pulling like 2 Volts AC
Problem: Without pulling the part out and stranding the vehicle at the shop forever.... I am trying to find the correct stator or at least one that might not be exact for the Massimo Buck 400S, but fit and connect and do the job if that makes sense.... if anyone has any ideas, please shoot them my way.
By Fmaxiron
Thanks a lot!
By BWF
I have a 2011 or so Landmaster LM200. I cannot get it to start. I turn the key and nothing happens. The brake switch seems to be working, the ignition switch works. The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine. I just can't get it to start by turning the key.
I am having a bit of trouble bleeding the brakes, not much fluid comes out at the calipers when I am pumping the brakes, though that an air bubble near the brake switch might make it not sense that the brake pedal is depressed.
I am at a loss, please help!
Brad
By paul allen
right front axle cv joint boot keeps getting torn up from the inside out....the stock one was damaged from a stick...i have replaced the axle 4 times with aftermarket axles that fit fine..after 4-5 miles of riding even on grass.the outer boot get torn up from the inside out...all 4 brand new alxes...bearings are fine nothing bent everything fits just fine....nothing seems to be binding.....any thoughts?????
thanks...pa
By AaronD1982
I recently purchased a 2019 or 2020 (no manual) Massimo 400S Buck Series UTV. It ran fine for a couple days but the low battery light was flashing while it drove. It then died in the field one day and I was able to jump the battery and get it rolling enough to get back to the barn. It started both times I turned the key for a couple days after and when driven died 10 minutes later in the driveway. Even after jumping it had no juice, but with the key out of the ignition it kept trying to start, a quick look on the Google machine and it suggested starter solenoid or ignition switch was the culprit. Fair enough, let's just order a replacement solenoid, right? No way Jose....the pin connector on the UTV is a 2-pin white plastic connector and the part received is a 4 pin. How do I swap that and make it work? Can I even? Where do I find correct parts in the future?
