2011 HS 700 EFI Radiator Fan Help
By doncaron
Hello everyone!
First of all I would like to thank you for the help with my timing problem, it was the chain. Now I’m looking for the part number for the wet clutch baring. I’ve been looking for it but my side by side is a 2022 t-boss 550 and it’s not the same as a 2021. Can anyone help me please?
thank you in advance again.
By htrotte
#1 While troubleshooting an issue with temp warning light I discovered another temp switch mounted in the pipe going to the head The two switches are literally 6 inches apart. Does anyone know what this third switch is used for? If i can figure out how I will post pictures.
Author #2 Finally got the pictures took. See the photo and tell me if you know what the switch on the right is.
It looks to be factory and I know the girl who bought it new and she didn't install it.
I can't find anything on it in any manual i have looked at. Any help would be appreciated.
By htrotte
By BOYD
By JimS409
I picked up this Hisun 700cc for a good deal. no crank no start unit 1900 miles on it. Put a new battery and starter solenoid fired right up but sounded rough some kind of rattle/clunk noise. Does anyone know what this noise could be? Couldn't get a better video of it running as i don't want to risk doing more damage. Drained the oil it looks good no metal in it.
445374820_7315077208620291_6073155782020130975_n.mp4
