    • By Butch
      I have a AXIS 700 EFI Fuel pump pressure stays at 40 psi and when return line is blocked the pressure goes to 60 psi. and wll only run with return line closed.
    • By Rmillerdesigns
      Hello. I have a 2016 Massimo MSU 500. I was putting on a lightbar and i screwed up and didn't disconnect the battery so when i was taking of the positive cable to put on the power from the lightbar it sparked and now the utv has no power. I turn the key over and all i hear is a chirp. No lights or anything. Everything that comes from the battery to the jumper box up by the battery shows voltage but anything coming out does not such as to the winch or anything like that
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By J Cardwell
      2024 villian overheating shuts down to crawl mode. If I turn it off for 30 minutes power returns to normal.
    • By oakhill
      When I am moving forward on my Hisun 500, the motor accellerates up and down while I have my foot on the gas pedal.  It also is not idling very well.  Both symptons appeared at about the same time.  What should I look for?  Thanks.
