I replaced the stator on our Bennche 500 because it was not charging. It ran as long as you kept the battery charged. I replaced the stator now it’s not firing. The only problem I found was a wire in the new stator for the crank position sensor was in the wrong place in the plug. I switched it around but still no fire. Putting a meter on those wires and cranking the motor showed no voltage from the crank position sensor. Something I did or a bad “new “ part? Thanks for any ideas.
  • Popular Now
    • By Jeff freeman
    • By mehe
    • By JohnnyB
      My Massimo 500 will not start. I’ve checked all the obvious things. It turns over just fine. fuel, spark, fuse box are all good. I can’t figure it out. Any ideas would be greatly appreciated. Thank you.
    • By AaronD1982
      Next problem with charging system to tackle, any help would be appreciated.
      New starter solenoid....check
      New Voltage Regulator...check.
      Dynamic test to Stator.....bang...pulling like 2 Volts AC
      Problem: Without pulling the part out and stranding the vehicle at the shop forever.... I am trying to find the correct stator or at least one that might not be exact for the Massimo Buck 400S, but fit and connect and do the job if that makes sense.... if anyone has any ideas, please shoot them my way.
