2018 Hisun Sector 750 Stalling
Chase
    • By Onebad54
      Has anyone solved the 750 Hisun Sector shifter problem?
    • By skittle021
      So I've got a Hisun 550 that I was doing some work on that required removing the CVT and it's housing. Upon attempting to reinstall the clutch, sheaves, etc, I found that the belt no longer fits - it's far too wide. None of the parts have been replaced, they're all OEM. Exactly the same parts as what I took off a few weeks ago.
      To be more specific, my belt is 1.25in wide, but the gap between the clutch and the primary sheave is only 7/8in wide. I'll include a few photos to explain.
      Has anyone ever experienced such a bizarre problem? Any help at all would be appreciated, I've been stuck on this for a month. I'm open to just about any suggestion.
      Photos:
    • By JFC
      I have a  3500LB Winch that only runs in one direction.  Inward but not Out.  Replaced the solenoid module.  Makes "click" when I push the "Out" button and the motor tries to spool out but then stops and begins to "click".   Does anyone have suggestions what I should try next?
    • By AL F
      CAN'T FIND ANYTHING UNDER 2005 THAT MATCHES  ARE THESE THE SAME   FUEL INJECTORS
    • By shaught66
      I bought my axis a couple months ago and noticed that when I turn my lights on, I have no tail lights, no licence plate light, and one of my high beams doesn't work. I switched the bulb in the headlight and the bulb works so it isn't it. I have brake and flasher lights but not tail lights. I have been waiting for a mobile tech but I would like to drive my utv at night. Any help appreciated.
