2015 Massimo 700 will not start
William Lyons
Engines need 4 things to start,
1. Fuel
2. Air
3. compression
4. Spark (at the correct time).
i would start by removing the air filter, and spray starting fluid or carburetor cleaner straight into the air intake, then try to start it, if it fires up, then dies, you have a fuel issue. It could be as simple as a clogged fuel filter also.
    • By mac66
      Just bought a used UTV, my first SxS.  It is extremely LOUD!   Was thinking of wearing shooting ear muffs to muffle the noise but then my passenger( wife) and I couldn't hear each other over the shouting we have to do now.... On the other hand we sometime ride with my brother and his wife and would like to be able to communicate. We throught about FRS and/or GMRS radios (we are licensed for GMRS) but we'd have to wear earphones under our ear muffs. My state doesn't require helmets to ride UTVs.
      I suppose if everyone has a cheap FRS/gmrs bubble pack radio with a ear phone we could all talk to one another. Just wear an ear plug in the other ear or ear muffs.
      Looking for suggestions.
    • By LongSun
    • By NDV45
      I have  2008 Cub Cadet Volunteer Tracker.  Was running fine, parked and next morning electric fuel pump inop.  Checked voltage had 4.2 volts.  Swapped relays in fuse box, checked all fuses (good) and still low voltage.   Does the ECU control the voltage to the fuel pump or which relay controls the voltage to the pump?
      Have checked all wiring and not found any place it could be shorted (not saying I may have missed something). I am at a loss.  Need Help Please.
    • By REDfletching
