By donny
Hello I am new here but have had this machine for about 5 years. I am having issues with it surging and sometimes sounding like a small backfire thru the intake. When putting in low, high or reverse it will struggle then go full power then struggle. It will only do the small backfire thing while in neutral reving it many times. Once in awhile it will throw a check engine light.
Parts replaced/checked:
I have checked the valve lashing, timing and adjusted. Parts replaced are the coils, spark plugs, injectors, fuel lines, fuel pump, IAC sensor, TPS sensor, throttle cable, speed sensor, primary and secondary clutch and belt.
By Randyh79
Does the transmission share the crank case oil with the engine or does it have its own oil seperate from the engine?
By Ermd ttk
Hello friends,
I got my ODES Ravager UTV yesterday and after a couple of hours of driving when I go downhill I heard a strange loud noise a couple of times, like a gear skipping or maybe something from the differential.
It doesn't always happen and when it does it is heard for a few seconds and then it goes away and everything works normally, I'm worried if there could be some major malfunction or what could be the problem if someone can help me?
Thanks a lot.
By Hugh
Cooling fans are working, I can hear it running once awhile if I can get the engine warm up enough. Thank you for all the help.
Hugh
