Lube Rack& pion steering
By great8redsfan
By Xov
By packersfan
I have a hisun 500 got from a auction and when turning a corner left or right it's a two hand job then when you left go snaps back.any help on what to look at would be appreciated.
Also blows blue smoke until she gets warm then it's ok
By NicholasNWM09
Hello Everyone,
COOL NEW Product Alert!
A company called NEW Wire Marine or NEW Wire has Badass custom panels for UTV, Buggy/Hunting trucks. From Fully wired switch panels with laser etched rockers with backlights in 5 different colors, to just parts like voltmeters, phone, USB and 12 v chargers. Rockers can be printed, or custom laser etched rockers and they even have sleek labeled pushbuttons. They are a first-class company with a great knowledgeable staff and outstanding customer service. Switches are based on 12v or 24v circuits and they also have marine grade wire and connectors, which is perfect for waterproofing your system!
Go check them out!
Check out the websites : https://newwiremarine.com/ and https://rockerswitchpros.com
By NicholasNWM09
Hello Everyone, COOL NEW Product Alert! A company called NEW Wire Marine or NEW Wire has Badass custom panels for UTV, Buggy/Hunting trucks. From Fully wired switch panels with laser etched rockers with backlights in 5 different colors, to just parts like voltmeters, phone, USB and 12 v chargers. Rockers can be printed, or custom laser etched rockers and they even have sleek labeled pushbuttons. They are a first-class company with a great knowledgeable staff and outstanding customer service. Switches are based on 12v or 24v circuits and they also have marine grade wire and connectors, which is perfect for waterproofing your system! Go check them out!!!Honda - xxxx - UTV Pioneer - xx'.pdf
