Popular Now
By rdc
By esmarkey
Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in. It still acts like the belt is slipping but now I am thinking it is the clutch?
Can the clutch be rebuilt?
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
By Sidewinder
