They are  built for a very severe duty, high discharge rate, application (which running a trolling motor or a television in an RV ain't),  Compare prices per Amp Hour (Ah) capacity rather than by voltage--you'll see the 8 V batteries are actually the same $$ or a bit less...
2 hours ago, JeraldWTulsa said:
Another question. Why six 8 volt Batteries and not four 12 volt for 48volt machine?
The power density (Ah capacity) of 4 commonly available 12 V batteries (starting duty or "deep-cycle") would be inadequate to the task--giving people something else to bitch about...
    • By OBL
    • By mike28honda
    • By Firewalker918
    • By AaronD1982
    • By Fmaxiron
