Coleman Outfitter 800-3 Owner's Manual
Popular Now
By Dave Jones
So with seat belt on I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
By John Gubancsik
After sitting this winter in a garage, I noticed coolant under the side by side when I went to get it out. Does anyone know what would cause the coolant to leak out while in storage? Any assistance would be greatly appreciated.
John
By mrpro
My 2022 Coleman/Hisun UTV 400 steering shaft has a couple of U-joints and angles to help get it down from the steering column to the rack. Today, my son who drives it most came in and said that it wouldn't steer and that he could turn the steering wheel but it doesn't turn the wheels I investigated and noticed that the bolt that clamps down the upper part of the steering shaft onto the lower one before the first u-joint in the steering shaft had fallen out. We haven't been able to find it, so I wanted to see what size and thread, bolt I should get to fix it?
By Ironhorse
New owner of a 2025 Bighorn Timberland 450LX. Looking for a link for a service manual for it.
Not having any issues, but I like to have them on hand for my equipment.
