Front and rear locking differentials, engine breaking
By Reynolds Rocket
By PossumTruck
Greetings,
By lmarkie
Any thoughts?
By Greg Kilgore
This started back in the summer.
While on a ride with the wife. Applied the foot brake and the pedal went to the floor. Thought the brake pads were gone. Ordered new pads. Removed the wheels to install new pads and they were in good shape.
So I bled all 4 brakes cylinders. Got thin dirty fluid out. Almost like dirty water. No air. Got a good pedal.
Then about a month later, same thing, brake pedal back on the floor. Could pump the pedal and get a little pedal back. Bled again and finally got a good pedal. The fluid was nasty like before. No air. And the fluid was topped off in the reservoir before I started the bleeding process.
Now same thing. Pedal going back to the floor. Reservoir still full. I'm thinking the master cylinder is bypassing. So have a new on on the way and will report back.
What do you guys think. Could it be something else.
I used one of those hand operated vacuum pumps to pull the fluid out of the reservoir when I was bleeding before. First time I've used one. And after a small amount of fluid filled the catch bottle. Seemed like the vacuum pump quit working. Had to close the bleed screw. Pump the brake one time. The start the vacuum thing again.
Again just wondering what you guys think. Using DOT 3 and DOT 4 brake fluid. Whatever I can get at a reasonable price at parts store.
By redneckred
Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X? I played with the gauges once and lucked up on this but can't remember what I did. Will the codes automatically display if there is a code or do you have to cycle through the display?
