My only comments is why, what is the appeal:
Is it the 8% less torque to the ground, plus power lost due to higher rotational mass--the 27s, just the tires,  will weigh 8 to 10 lbs more each; the wheels another 4 to5 lbs. each--(probably another 47, so -12% in total)?
The 5% speedometer error (it will read slow vs actual speed)?
Re: spacers;
Is it the added stress to the axle bearings and all other suspension components?
Higher unsprung weight (12 to 15 lbs. per corner) guaranteed to deteriorate handling and ride;
Or that they will "look real cool"/
They look great but other than looking cool, I dont see the need.. Like Cliff says ,you will lose torque from the reduction of gear ratio........ Wider  tires , sure.. taller , nah... besides I run on some  State Wildlife Management trails.. Wheel size and lug depth are limited by regulations but width is not.. And they enforce it rigorously ,so ........ But if you dig it, by all means go for it dude.. Its yours ..light em up
Thanks for the reply. I ride a handful of times a year in the Ozark mountains where I constantly have issue with big rocks hitting the skid plate and a few off camber situations. My plan is to only run the bigger tires and spacers for these rides and keep the stock wheels as is for around the house applications.  I feel like it will hold up for 40-50miles at a time 3-4 times a year. Just seeing if anyone has issues or experience with these
Update. Installed 27x9x12 in front and 27x11x12 in rear. No spacer required to gain clearance and  no noticeable impact to steering/ handling. Slight impact on stopping power at higher speeds. Did gain 1 1/2in extra clearance in front and back. I’ll update as issues arise that I feel relate to this.
PICTURES  dude c'mon man
Definitely notice the width difference.  Did you have to remove the side rock guards for clearance or did yours not have them?  Like the light bar too - just finished putting  an extra set of led cubes I had sitting around on mine last night.
    • By Flanman55
      I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly.  The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
      any help would be great.
      thanks
    • By GunnersTacklebox
    • By Bbicon
      I have a 2014 odes 800 dom. I  have a wire in the same harness as the fuel pump plug ( just before it ) and it is not connected to anything t has a connector and a little brass connector on the end , I was wondering if anyone could tell me where it goes to
    • By Dennis
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
