Hello all. I have a 2005 Joyner sand spider 650 with the dreaded broken output shaft on the transmission. I got ahold of a 2007 joyner commando 650 for cheap that had a bad motor but a good transmission. I got it because everything i read said that the transmission would work but it seems that it will not. Due to the commando being 4x4 it has a selectable locker and a small ring gear using a "idler" gear to turn the ring gear which make the output spin the wrong direction. Is there any way that I can make this thing work? I really dont want a commando, I like the buggy but if the trans wont work then I can only put my motor in the commando. Any help would be appreciated. I have the ring gear from the original trans but the shaft is broken and the shaft from the commando wont fit the ring gear it doesn't appear.
Ran fine parked it in garage and 5 days later would not start or make any noise trying to start. Bought new battery, installed it and still nothing, no noise or anything.
Any idea? I can’t figure it out since when I parked it, it was running great.
I made my first oil change on a axis pro 750 I bought from lowes. I found a substance that looked and felt like rubber bands in the oil filter and oil strainer at drain plug. How in the world does this happen unless done on purpose at Hisun factory or assembly. Has anyone else seen something similar?
