Engine sputtering/power loss ****Fixed**** Bad TPS
Popular Now
By rdc
By 180gtr
Wheels
Tires
Engine
Transmission
Axles
Shocks
Control Arms
Throttle Body $90
Starter $150
Alternator $150
fuel pump $70
Map Sensor $50
Full set of Guages $150
Exhaust w cat, O2 SOLD
Ignition Coil - SOLD
Wiring harness and ecu SOLD
That would include....
Steering shaft, wheel
Ignition switch, key
Light bar frame, 2 lights
misc hardware, spindles
2 hubs, rotors
Engine mounts
Throttle pedal, cables
Shifter, cables
Clutch master, pedal
By Jody Deville
By Big Red Dog
Bought my 2009 Yamaha Rhino, (fuel injected of course), recently from the original owner. Only had 500 miles and 70hrs. Starts reliably, however, it will not idle but about 50% of the time. Also, when driving slow in low or high, that is to say, relatively low rpms and below about 10 mph, it bucks and almost wants to die..... not smooth at all. However, at speed (say 12-15 mph or more) it runs very well, like it should. Any ideas?
By schreib69
I just bought an older (2008) Teryx 750 and am having some concerns. Hoping of course, that most are not too big. . . but more knowledgeable folks like yourselves will surely have some ideas. Thanks in advance.
-- about 2700 hrs, camo version
-- Starting: after not running much at the auction site, I tried it and it was tough to start but half of this was likely I did not quite know the tricks for how long to keep the choke on. However, once it started it was kind of hard to keep running until it warmed up(once warmed it starts perfectly every time with no choke). Now, back to running after the first ignition: I had to hold the RPM's up a bit to keep it running and when doing so it sounded as if a little gnome was inside the engine pounding on something at random intervals. Wondering if this could be detonation-- "knocking"? After warming, it disappeared completely. Maybe just need higher octane gas??
-- After starting and running a bit there was a pretty terrible smell, most "like" burning rubber or an electrical fire. No fire or resolution of this. Eventually this TOO went mostly away, but still basically present. Could it be adjustment needed for the main belt variable speed tranny?
-- When I move from neutral into either Lo or HIGH range forward gears, I get gear clashing. I did NOT put foot on brake and read in manual(just NOW) that you are supposed to do so. (I have NOT gotten back out to check and see if this matters. ) OR, could it be part of the drive system is mashed up??! Geez, hope not.
-- There is a big open hole allowing direct sight into the belt transmission on the back right side. This can't be normal, it must require some plastic cover. Right? Any rodent could get right into the transmission!
-- THere appears to be no muffler or spark arrestor unit. This "could " be the cause of some of the smell. . . ?? but that should not smell like burning rubber or electrical smell. . .
SO. That is all.
I sure would appreciate any insight on this issues and finally(!). . . if I was to take this into a local dealer what would you say are the top three issues I should have them address first?
thanks!
