Thought I’d post this in the general forum to try and get some more ideas.
2008 Joyner Renegade
800cc EFI Chery engine
1100mi
Starts and idles fine, drives well until you actually try to go, then starts to sputter as if it’s starving for fuel. Does this no matter what fuel pressure I set it too. I’ve tried 35-80psi
New fuel pump
New fuel filter
Cleaned injectors
New thermostat
Fresh Fuel
Any smarty smarts out there with ideas?
I thought that too, but it’s just the super skinny tips make it look like the gaps are huge, did just pickup a feeler gauge though, we’ll see whet they are currently at. Any idea what recommended plug gap is? .035…..
3 hours ago, T-boss 410 said:
What are the spark plugs gapped at? It's probably just the pic, but those gaps look kinda big.
Gap was about .050, gapped them to .030 and ZERO difference 😕😕😕
13 hours ago, T-boss 410 said:
According to my service manual, the gap for mine is 0.6-0 7mm. Not sure how that converts to inches. But, it is a moot point since you already regapped the plugs.
.023  -  .027 thou
  • Mike_Metzger changed the title to Engine sputtering/power loss ****Fixed**** Bad TPS
3 hours ago, Joe Breaux said:
so, Throttle Position Sensor was faulty?  that will cause problems
Yes, I missed it because I noticed there was a spare TPS in the glove box. Swapped em out and  it would barely run. So I put the original back on, but never actually tried just unplugging it. Once I did that, holy $hit does this thing rip!
.023-.027 gap
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
    • By Jody Deville
    • By Big Red Dog
      Bought my 2009 Yamaha Rhino, (fuel injected of course), recently from the original owner. Only had 500 miles and 70hrs. Starts reliably, however, it will not idle but about 50% of the time. Also, when driving slow in low or high, that is to say, relatively low rpms and below about 10 mph, it bucks and almost wants to die..... not smooth at all. However, at speed (say 12-15 mph or more) it runs very well, like it should. Any ideas?
    • By schreib69
      I just bought an older (2008) Teryx 750 and am having some concerns.  Hoping of course, that most are not too big. . . but more knowledgeable folks like yourselves will surely have some ideas.  Thanks in advance.
      -- about 2700 hrs, camo version
      -- Starting:  after not running much at the auction site, I tried it and it was tough to start but half of this was likely I did not quite know the tricks for how long to keep the choke on. However, once it started it was kind of hard to keep running until it warmed up(once warmed it starts perfectly every time with no choke).  Now, back to running after the first ignition:  I had to hold the RPM's up a bit to keep it running and when doing so it sounded as if a little gnome was inside the engine pounding on something at random intervals.  Wondering if this could be detonation-- "knocking"?  After warming, it disappeared completely.  Maybe just need higher octane gas??
      -- After starting and running a bit there was a pretty terrible smell, most "like" burning rubber or an electrical fire.  No fire or resolution of this.  Eventually this TOO went mostly away, but still basically present.  Could it be adjustment needed for the main belt variable speed tranny?
      -- When I move from neutral into either Lo or HIGH range forward gears, I get gear clashing.  I did NOT put foot on brake and read in manual(just NOW) that you are supposed to do so.  (I have NOT gotten back out to check and see if this matters. )  OR, could it be part of the drive system is mashed up??!  Geez, hope not.
      -- There is a big open hole allowing direct sight into the belt transmission on the back right side.  This can't be normal, it must require some plastic cover.  Right?  Any rodent could get right into the transmission!
      -- THere appears to be no muffler or spark arrestor unit.  This "could " be the cause of some of the smell. . . ??  but that should not smell like burning rubber or electrical smell. . .
      SO.  That is all.
      I sure would appreciate any insight on this issues and finally(!). . . if I was to take this into a local dealer what would you say are the top three issues I should have them address first?
      thanks!
