Just purchased a new Coleman UT400 and came across your forum searching for info and wanted to get in on the fun. We have had a golf cart that wasn't really up to the job and pulled the trigger on the Coleman. We only have 5 acres and this seems to be a good match. So far I have been pleased with the purchase but like several others the manual is not correct but I  have already found very useful information here 😀20210803_123459.thumb.jpg.635d7d909a790cb280179be065822475.jpg20210730_160205.thumb.jpg.e87ca295dafe9f8f912227855df153d0.jpg
    • By Dave Jones
      So with seat belt on  I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
    • By MilSurpYinzer
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
