could somebody tell me how to wire up the starter solenoid. I have put positive lead from solenoid to postive battery. Then I put starter cable to negative post on solenoid. Main fround wire to neg battery. Is this coorect because I get nothing.
Positive and Negative should never touch directly together or be hooked to the same component. Generally, there is a Cable from the battery, to the solenoid post, then another cable from the solenoid to the starter.
What model HiSun do you have?
  • Alex changed the title to 2013 Hisun 500 starter solenoid
    • By jertex
      I have two questions:
    • By OBL
    • By Jeff freeman
    • By Garjess
      My rtv 1140 won't turn over.  I've jumped the neutral switch, and the brake switch, and checked the ignition switch. I'm not getting any power to the trigger wire on the starter solenoid.  It starts fine with the key on and putting power to the trigger wire on the solonoid.
