Does anyone know what kind of skid plate is on the 2022 Kawasaki Mule Pro MX? It’s obviously plastic but I know there are different grades of plastic. I’m unable to find any information about it on the web. Also any issues with plastic vs metal?
    • By Xov
    • By Tim n Deb
    • By Flanman55
      I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly.  The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
      any help would be great.
      thanks
    • By KWinTX
    • By Aaron Colona
      Just bought a brand new 760 about a month ago. I'm at 20 hours which the book says is when you need to change the break in oil.
      I must be crazy, but I can't find the oil filter. I've googled a million videos...everything seems to be 2019 or lower...and/or a 550.  They all show the filter easily seen by looking in past the rear passenger tire on the engine. There is absolutely nothing there on mine.
      1.there seems to be very little info if you Google a 760, or anything Massimo newer than like 2019.
      2. Does anyone have a current model year 760 that can answer my riddle for me?
