Hisun vector 500 won’t start
By Joe Rizo
Hello All,
1. Fuel pump (new)
2. Fuel sensor (new)
3. Fuel injector (new)
4. Battery (new)
6. fuses (12v to all)
13. replaced air filter
By Rschrem
Hi, my 2010 Hisun will crannk but comes to a stop and only clicks. It has new battery and solinoid. Battery connections all seem good. Any ideas what the problem is?
By Tim n Deb
Riding out today it acted like it ran out of gas, stalled and died and would not start. Towed back to house, New plug added this past month, plenty of oil, getting plenty of gas, battery cranks good. Trys to kick in and starts but doesnt. Two days prior while sitting at a idle it died. Added gas and it started did my ranch chores with it. But just now it stalled out cranks but will not start. Tried to find if fault codes came up on the clock like manual says but not sure I am doing that right. Any and all help apprecated. Thank you
By Frank Mac67
- NO CLICK - NO OTHER NOISE
Can anyone help?
Can anyone help with this?
By monkthumper
