2009 Hisun 700.
Well, back to square one.
I've been doing this rebuild since Jan. 2021. MANY new parts and fixes and re-starts and working/then broke/then working/then broke... and on and on. Last week I had a good ride, about 18 miles. Ran great. Parked in the garage for 2 days and then the exact same problem as last time-- Cranks and cranks, about 6 or 8 times, and then click: nothing. I get one click and a red warning light on the dash but it's too small and doesn't say what it is. It's not the battery: it's fully charged. Had it on a charger overnight afterward and still getting one click. It's like the starter is stuck or the engine is seized. The last time it happened I took it to a guy who's rebuilt many of these and he found the starter was full of oil! Black oil. He said it was black 'cause it got cooked trying to crank. Put in a new starter and he did all kinds of adjustments and between him and the neighbor it was running great. Now it's stuck again. I'll pull the starter when I calm down....
One of the MANY new parts we threw at it was a new battery. it's got plenty of power, 350 cold cranking amps. Is it possible to have TOO heavy a battery?
But has ANYONE run into this? 🙁
Well the good news is, the starter's not full of oil this time. Bad news is, the connection point is melted inside. I'm thinking something jammed inside the crankcase and the started was trying to turn against the jam and melted.
Yup--- Did that today. It turns easily in one direction and slow-but-sure in the opposite direction: compression. But it does move so it's not seized.
I fished a piece of a ball cage out of the oil filler spout several months ago and I've always felt that there must be other metal junk down in the case. I had a guy working on it but he didn't have an indoor place to take the crankcase apart to check. He did get it all timed and valves set right and it ran good once or twice. The last ride was about 18 miles with no problems. Then it sat in the garage for 2 days and wouldn't start: just cranked and cranked. Until it locked up, I guess from the starter melting. But I didn't crank long, just 6 or 8 normal cranks and was about to give up but it locked and smoked. So ... there it sits.
Interesting, the rest of the cage bearing must be in the case. Not good! Did you drain oil from engine when you found cage in spout? If not, do so and meticulously inspect oil for foreign matter.
Did you turn motor over several revolutions by hand? Did you hear or feel any grinding or resistance? Remove spark plugs prior to test.
What is voltage at signal wire of starter when turning key to start position.
You may have two issues, electrical and mechanical.
Oil change--- I didn't. It went to a mechanic and he did all kinds of work on valves, etc., had the valve cover off and did some things... (I know Jack about engines so I leave it to more knowledgeable people).  He did say he didn't see anything in the oil when he drained it. I had told him about the ball cage and he didn't find any debris or metal shavings . I don't know for sure if he emptied out the oil or not. I plan to borrow a neighbor's magnet/stick today and fish it down in the oil spout and see if it brings anything up.
I will try again to turn it with the plug out and try and do several revolutions.  I'll check voltage, too.
Thanks.
    • By Rschrem
    • By Xov
    • By Tim n Deb
    • By Chile
      Chile
    • By Chile
      2018 Massimo MSU 700 EFI. I realize that this engine is essential the same as in all of the HISUN based Yamaha clones out there. I am in the process of performing a top end diagnosis/rebuild. I have an AMAZON top end rebuild kit on order in anticipation of this activity.
      Question 1:  When exploring the myriad of top end rebuild kits on the market for these units there are some cylinder assemblies that have "686 cm3" badging next to the cam cain tensioner boss. Others compatible with the unit do not have this badging. The existing cylinder assy does not have the 686 badging. I am assuming that this simply verifies that the cylinder assy is for a 686 cm3 engine which of course the stock 700 series HISUN engines are. Am I missing something here or is this just a manufacturer artifact? With or without the badging the application listings all indicate compatibility with the MSU 700 series engines.
      Question 2:  I have reviewed at minimum a dozen videos associated with this rebuild. To date I have not found one that deals with piston/cylinder clearance and/or ring gap verification. The advertised specifications for these various "top end rebuild kits" all indicate: Cylnider bore = 102mm and piston diameter=101.5mm. The math yields a .5mm (as in 1/2 mm) difference. That seems to be a very large piston/cylinder clearance.  I realize I am referencing advertised specs rather than emperically measured values but the numbers have gotten my attention.  I have referenced the FSM and found it to be somewhat confusing in this regard. Hopefully the experts on this forum can enlighten me as to where my observations are faulty here.
      Any and all assistance is greatly appreciated .
      Thank you all in advance,
      Chile
