  • 1 year later...
Brandon:
please let me know when you find the 2009 commando 650 cc right and left rear axles. And ship them to my address in wv so my mechanic can install/ replace.
please let me know is you need any additional information.
William Moore
1065 Potomac Overlook Drive
Levels WV 25431
54 minutes ago, William Moore said:
Brandon:
William Moore
Levels WV 25431
Hi Brandon,
What I know is 650 Commando has front left and front right cv axle and same rear left and right cv axle.
 I have all the axles ( both front left, right and rear ) for 650 Commando.
 The rear cv axles you are looking for is available. Please refer to attached photos.
 The axles are currently stocked in South Carolina. If you order, they will be shipped from South Carolina by UPS.
 The cost is USD250 per piece ship to door ( shipping included).  Id like to offer you discount if you order two pieces together.
If you confirm to order, please send payment to my Paypal account: [email protected].
I will arrange shipment and provide you tracking number.
Best regards
Casey
2023-11-27
    • By nrggaragebuilds
    • By mrpro
    • By OBL
    • By Firewalker918
