My Massimo 400 buck started blowing white smoke out of the muffler. Anyone tell me what is creating that. I immediately parked it and afraid to crank it until I know what to fix. Please help if you know. Thanks
T-boss 410 is correct, and a bad head gasket is probably the cause. White smoke is definitely coolant.
I'd try to verify, by using a leak down test first. It's a common, yet simple test. If you're unfamiliar, Tube can explain it.
The tool should be available from o'Reilly auto parts, loan a tool program, but call to verify availability. You buy the tool for extremely cheap, then return it when you're done, for a full refund.
The test is cheap, and easy. Unfortunately the fix is neither. But it's certainly a doable project.
its the head gasket ..or a cracked head... been there ..mine had both ..there are videos o repair if you feel up to DIY  . parts available online. if not, find a mechanic willing to work on these. typically about $400-$500 for gasket
    • By Adrian Domingues
      Thanks for your help
    • By Firewalker918
    • By Eman85
    • By JohnnyB
    • By AaronD1982
